Change the Curve Color
- From the HyperGraph 3D Curve Attributes panel, select the Surface tab.
- Deactivate the Contour checkbox, if necessary.
- Select a curve or curves from the Curves list.
- From the color palette, select the new color for the curve.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Loads Flux motor efficiency files in text format.
Edit existing curves or add new curves to the current plot.
Create waterfall plots from XY force response data and input pulses.
Define curve attributes.
Add axes to plots.
Retrieve individual point data on any curve in the active window.
The Data Query panel uses vertical cutting surfaces for viewing and plotting non-planer cross sections.
Provides quick access to the Datums and Notes tools.
From the HyperGraph 3D3D Chart modeling window, right-click to display the context menu.
