Use a File as a Data Source
- From the Bar Chart Define panel, select .
Click the file browser button,
, and select a data file.
- Select a vector data source by specifying the Type, Request, and Component.
- Click Apply.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
ON THIS PAGE
ON THIS PAGE
