Use Math as a Data Source
- From the Define panel, under Source, select Math.
 - Define the vector using the curve calculator to create a mathematical expression.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Edit existing curves and add new curves to the current plot.
