Values
Retrieve individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
See Values for more information.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Edit existing curves and add new curves to the current plot.
Add horizontal and vertical datum lines to plots.
Displayed immediately upon curve selection, the tip-to-tail function calculates and draws the tip-to-tail function based on the current plot.
ON THIS PAGE
ON THIS PAGE
