Attachment Wizard Dialog
The attachments specified during the assembly process (using the Assembly Wizard dialog) can be modified using the Attachment Wizard, located on the Assembly ribbon. The Attachment Wizard dialog guides you through the process of modifying the model attachments.
Next
Moves to the next panel.
Back
Returns to the previous panel for review or edit.
Finish
Closes the Attachment Wizard.
Message Log...
Displays the message log at the bottom of the dialog.
Clear
Clears the message log.
Note: This button is only activate if the message log is displayed.
Model
Suspension
Struts
Figure 3.
Rackpin Steering
Figure 4.
Steering Column
Figure 5.
