Set Wizard Paths Dialog
The Set Wizard Path dialog allows you to select directories in which several files are stored.
  • Assembly Wizard file
  • Task Wizard file
  • MDL standard include file
  • Wizard library directory
  • Report log file
From the Assembly ribbon, select Set Wizard Paths to access the dialog.
Figure 1. Set Wizard Paths Dialog
Select Use values from preferences file to use the default paths for the files, or use the individual file browsers to select the desired paths for the files.
OK
Applies the changes and exits the dialog.
Cancel
Exits the dialog.
