FIALA Road Modeling
FIALA tire model supports all the 2D and 3D road models available in Altair Roads and also a Drum Road where the drum surface is described in a table of height verses drum circumference.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
ON THIS PAGE
ON THIS PAGE
