Shock Absorber Systems
The Shock Absorber system models a conventional shock absorber and the bushings at the top and bottom of the shock.
The shock absorber resolves into two different joint types based on the selection in the Assembly Wizard.
Shock Absorber with Inline Joints
Shock Absorber with Cylindrical Joints
Auto Damper
