Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Create and edit user-defined data type expressions, derived load cases, and systems. You can also plot a forming limit
diagram, generate streamlines, track entities during animation, and create and import/export sets of entities.
Query entities, create or edit free body diagrams, construct multiple curves and plots from a single result file, and
create and plot stress linearization.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
The Report Configurator tool allows you to quickly create a Word document or
pictures.
Entity Selection
Select available Components
(Parts) and/or Element Set; with the sub-option Isolate Selected/Contour on Complete Model,
the selected entities will contoured and isolated on the screen or contoured only on the whole
model respectively. Figure 1.
Select Load Cases
Select one or multiple load cases (each load case is structured as unique entity from the
combination of its subcase ID and its simulation ID). Figure 2.
Result Configurator
Two different options are available:
Set Up on Active Window
Figure 3.
With this option you can insert the configuration of results for which you want to
extract an image using the Add Rows button. Figure 4.
Once a row is added the result configuration can be set up picking from the
following available options:
Data Type
Data Component (if available in the selected Data)
Layer (if the selected result is layer based)
System
Corner Data (on/off)
Averaging (method)
Legend File (if to be used or not)
File Path (to Legend File: *.tcl) Figure 5.
You can also:
Remove rows
Duplicate selected rows
Save the config (in the form of a CSV file) Figure 6.
Load the result config (from a CSV file)
Clear the current window contour in HyperView (if required)
Select from Session
Figure 7.
With this option you will get for each page and window in the current session
where HyperView is loaded, the result configuration of
each HyperView client. This configuration cannot be
changed, however the result to be exported can be selected by checking the box at the
very left of the tree widget. Figure 8.
It is important to point out that the components and set listed in the Entity
Selection box are referring to the model in the first available HyperView client. The process is therefore tailored to have a
session (or report template) pointing to HyperView clients
featuring (at least) the same model (structure).
The export options are:
Export to New Word (for Windows system only)
Export Using Existing Word (for Windows system only)
Export Pictures (for Windows and Linux)
Export to New Word
This option will generate a new chapter for each selected results. Each chapter will have a
sub-chapter for each selected load case which then will have again a dedicated sub-chapter
for each selected parts.
For example, the below configuration: Figure 9.
Will generate: Figure 10.
This approach is similar to the previous one, however you will be asked, after the
selection, to point to an existing document or template. The organization of the chapters is
the same as the previous use case, however the headings will be taken from the document set
up.
For example, the below configuration: Figure 11.
Will generate: Figure 12.
Export Pictures
After selection of the configuration, you will use these functions to input a destination
directory in which the tool will create a subfolder for result, then a sub folder for each
load case, and then a picture for each selected part/set.
For example, the below configuration: Figure 13.
Will generate the following folder structure: Figure 14. Figure 15.
