HyperWorks
HyperWorks
2023
  1. Home
  2. Results Data
  3. Results Data in HyperView
  4. Animate and Visualize Results
  5. Contour
    Use the Contour tool to create contour plots of a model and graphically visualize the analysis results.
  6. Create and Manage Contour Plots
    Learn about creating and managing contour plots.
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • PhysicsAI
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
Index
HyperWorks
HyperWorks
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
    • Results Data in HyperMesh
    • Results Data in HyperView
      • Working with Models
      • Animate and Visualize Results
        • Create and View Section Cuts
          Use the Section Cut tool to cut planar or spherical sections through a model.
        • Contour
          • Create and Manage Contour Plots
            • Create a Contour Plot Based on Nodal Results
            • Create a Contour Plot Based on Elemental Results (Including Corner Results)
            • Change the Display Options
            • Manage the Legend Display
            • Overlay Result Display
            • Clear Contour
            • Create Plot Style
            • Control the Display of Iso Values
            • Select a Projection Rule
            • Query Results
          • Color Band Generation
            A contour plot generates color bands on the model, based on the values found in the results file.
          • Additional Comments
          • Layers
            Layers allow you to display a contour for a specified element layer when a layer definition is available for an element.
          • Value Filter
            The Value filter available in the Contour panel allows you to specify threshold criteria for processing results only in a specific range.
          • Composites Post-processing
            Composites post-processing is enhanced in HyperView with the reorganization of ply results as layers.
          • Cache Results
            After a contour plot has been applied in the Contour panel, the Cache feature will become active and allow you to add the currently active contour result to an internal cache.
          • Mid-side Node Elemental Results in Contour
            Mid-side nodes refers to the nodes in between the corner nodes of the 2nd order elements.
          • Post-process Abaqus Stress Results
          • Post-process Stress Results (solver independent)
        • Iso
          Use the Iso tool to display single iso values (iso surfaced for solids or iso line for shells) dependent on results data.
        • Vector
          Use the Vector tool to set options for a vector plot.
        • Tensor
          Use the Tensor tool to view tensor plots of stress and strain directions and magnitudes for various solvers from elemental values.
        • Refresh Results
          Refresh Results is a convenient way to quickly refresh a result plot (contour, vector, tensor, or iso) whenever the display changes.
        • Edit Legend
          The Edit Legend dialog allows you to change the legend properties.
        • Graphical Editing of the Legend and Iso-slider
          You can edit the contour, vector, or tensor plot legend in the graphics area.
        • Complex Results
          Results in some analysis types come as complex numbers.
        • Computed Results
          A listing of results that are computed in HyperView.
        • Nodal Averaging of Elemental Results
          Nodal averaging of elemental results at a node refers to the average of all the element corner results passing through that node.
        • Averaging Options
          The averaging options allow you to limit the averaging of results to only a group of elements that are considered to be bound by same feature angle or face.
        • Multi-model Result Plotting
          HyperView allows for plotting (contour, iso, vector, or tensor) across multiple overlaid models.
        • Fatigue Manager
          The fatigue manager allows you to write stress and strain results from a finite element analysis to an external file that can be used to set up a fatigue analysis.
        • Fatigue Configuration File
          The fatigue configuration file is a user-defined external ASCII-file through which the data groups from results of static/modal/transient analysis of different solvers can be read.
      • Create Entities
      • Query Data
      • Annotate Models
      • Transform Models
      • Overlay Images/Videos
      • Rendering Models
      • Additional Tools for Post-Processing
      • Profiles
      • Preferences Dialog
      • Display/Visualization Options
      • HyperView - MultiCore
        A new workflow emphasizing the multicore profile for standard crash post processing use cases.
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
HyperWorks
HyperWorks
2023
  1. Home
  2. ...
    • Results Data
    • Contour
  3. Create and Manage Contour Plots
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
ON THIS PAGE
    • Clear Contour
    • Create Plot Style
    • Query Results
    ON THIS PAGE
