The NVH library contains operators which are used for frequency domain and acoustics
functions.
All operations in the NVH library operate with complex
data and output complex data. This may seem counterintuitive, considering all the operations
available (at this point) should be viewed as real data (the imaginary part will always be
0.0), but because data types get added to an existing subcase, and the subcase is complex, the
output of these operators should be viewed at 0˚ within the application.The acoustics
operators are designed to maximize flexibility and are designed to work together, and can
accommodate both vector and scalar participation input.
