Plug-in Library
The Plug-in library provides support for applying a compiled or interpreted script operation on a value table.
| Event | Arguments | Description |
| Begin | table_info | Called once before the data type is read for a given pool and layer. The table_info argument is an object/function that allows the table to be queried. |
| OnRecord | record_info, record_action | Called for each record being processed in the data type. The record_info argument is an object/function that allows the record to be queried. The record_action argument is an object/function that allows data to be output to the destination value table. |
| End | table_info, record_action | Called after all records have been processed for the data type pool/layer. |
The query/action objects allow the plug-in to query the data passing through the data type request as well as the entities directly attached to the value. They have the same basic signature, independent of the plug-in type (C++/Templex/Tcl):
| Function | Property/Method | Description |
| table_info | label, domain type  |
                Label the table label. Domain of the table (real, complex).  |
| record_info | id, data, count, part ID, system ID, dimension, numeric Type, domain type  |
                Entity ID of the value record. Data within the value (scalar, vector, tensor). Number of value items (>1 for corner-bound). Part ID the element belongs to (0 for nodal). System ID for directional values. Dimension for tonsorial values. Numeric type (float, double). Domain type (real, complex).  |
| record_action | AddRecord | Supports the addition of a value to the destination value table. Records can be added in the OnRecord or End event only. |
| option_string (scripted plug-ins only)  |
                GetOption, GetOption(key)  |
                Returns the optional argument passed for the “opt_str” argument. Any argument passed that is not recognized as a function parameter will be added to a key/value pair list of optional arguments that will work with the GetOption(key) form of this command. The second form of the optional argument setting/getting is available only via XML, and not through the Expression Builder. |
