Create and Edit Charts Using Results
Create charts using the data read from a results file by directly reading a result datatype, or by tabulating the data in the Matrix Browser.
Please follow the instructions at Create and Edit Charts.
A results database contains translated results files, which are read into HyperMesh for post-processing.
Import analysis result files to create plots, query results, and so on.
Use the Results Browser to review and manage results and plots.
Use the Contour tool to visualize result data by coloring entities by value, allowing for easy identification of maximums and minimums throughout the model. Contour plots can be created using any scalar data, including components or invariants of vector or tensor results (for example: vonMises stress, displacement magnitude).
Use the Vector tool to draw arrows such that the direction in which the arrow points is the direction of the vector and the length of the arrow is its magnitude. Individual vector components, shear, and complete resultants can be plotted for vector-based results (for example: X, Y, Z, Resultant).
Use the Tensor tool to show stress and strain directions and magnitudes for various solvers from elemental values.
Use the Deformed tool to specify parameters for deformation display. This displays the original structure and the deformed shape to see the total amount of movement, or view the deformed shape by itself.
Use the Marker tool to visualize result data by adding text on entities by ID and value, allowing for easy reference of result values on selected entities. Marker plots can be created using any scalar data, including components or invariants of vector or tensor results (for example: vonMises stress, displacement magnitude).
Use the Beam Stress tool to display a contour of stress distribution on a tessellation of a beam cross section.
Use the Legend entity to create, edit and assign custom legends to any contour, vector and tensor or marker plot. Legends can be numeric, or category based. It can be copied or saved to an external file and imported for re-use.
Calculate free-body forces, moments, displacements, and rotation.
Seamlessly process solver native results in HyperMesh.
Use the Matrix Browser to explore the HyperMesh and HyperView data entities and export the entities to external files for further analysis.
ON THIS PAGE
ON THIS PAGE
