Control IDs from Selection
Use the Control IDs from Selection tool to create a list of selected nodes/elements, review and control IDs.
Create an assembly structure from a .csv file definition.
Use the Orientation Review tool to display/review and modify frequently used coordinate systems used in CAE analysis.
In the modeling window, display mass, center of gravity, or moment of inertia as markers.
Use the Plot RBE/MPC tool to plot RBE and MPC considering a RBE3/MPC with a given weighting factor where the nodes are written in a certain displacement coordinate system.
Use the Dataname Viewer tool to display either scalar or new marker plots on elements/nodes associated to their data names and attributes. For elements the link can be extended directly to the associated properties and materials.
ON THIS PAGE
ON THIS PAGE
