Field Looper
Use multiple combinations of source files (in the form of CSV) and multiple target models (decks or HyperMesh .dbs) to realize field mapping for the creation of new loads, such as temperature and pressure.
Field Looper works in full batch mode and the setup of the mapping is done through a dedicated graphical user interface table. The setup can be saved and retrieved through a .csv file.
