Convert LS-DYNA to Radioss for Airbag Folding
Use the Presimulation tool to convert the airbag to Radioss format and prepare it for the next folding steps.
Use the Read Positions tool to read .h3d node positions.
Use the Stitching tool to attach the various patches by moving patches and merging boundary nodes.
Use the Create Table tool to create a table on which the airbag will be folded.
Use the Flatten tool to flatten the airbag.
Use the Housing tool to fit the airbag to housing/container.
