Create a Tuck Fold
From the Airbag ribbon, click the
Tuck tool.
On the guide bar, click .
- GAP: The gap that will be used in the contacts generated in the pre-simulation model.
- Folds Directory: The location where the results of the run are written.
- On the guide bar, click Components.
- Select the airbag components.
Set advanced selections as necessary by clicking on the guide bar.
- On the guide bar, click Nodes.
Select the border nodes of the portion of the airbag to be tucked.
The nodes are applied to an imposed displacement in the pre-simulation model, like the blue arrows shown in the picture above.
- On the guide bar, click Export to generate the pre-simulation deck to be run.
- At the end of the pre-simulation run, click the satellite icon to load the new positions from the resulting .h3d file.
