Solver Cross-Sections
Create solver cross-sections on the seatbelt mesh.
Creating cross-sections allows you to automatically create solver cross-sections at a given distance from the start and end of the seatbelt.
Position a dummy model using the Dummy Browser.
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
Use the Seatbelt Browser to create a complete seatbelt system.
Create a complete seatbelt system, with meshed fabric components and solver-related seatbelt features.
Create a seatbelt mesh.
Auto-extraction from the FE model allows for a quick recovery of the seatbelt system without having to recreate the seatbelt.
Apply tension to a seatbelt for testing using the tensioning option.
Create solver seatbelt features using Control Points.
Use the Link Dummy Mechanism to update dummy and seat motion.
Use the Barrier Positioner tool to automatically get the impact barrier into position, based on the selected crash regulation.
Use the IP Impact tools to automatically calculate the instrument panel (IP) testing area according to the regulations FMVSS201 and ECE-R21, position the headform impactor, and export ready-to-run solver decks for all the selected impact locations.
The Pedestrian Impact tool automates the vehicle marking, impactors positioning and the export of solver decks with minimal input, therefore reducing the full process lead time.
Use the Safety ribbon to access crash and safety post-processing tools.
The Altair Safety Report Manager (ASRM) is a fully customizable automatic report generation utility for crash and safety regulations.
