Combine, Subtract, Intersect, Detach Solids
Use the Boolean tool to combine solids, subtract one solid from another, detach solids, and find the intersection out of the solids.
Use Parasolid
This option is added to allow you to use the Parasolid geometric kernel for performing boolean operations like combine, subtract, and intersect.
Key Differences
Here are some key differences between using classic and parasolid geometry.
You can review problem areas and either fix or isolate them by trimming solids so that the remaining solids can be successfully processed for the boolean operation.
