Interfacing with Abaqus
Overview of how the HyperView applications interface with the Abaqus solver.
Reading Abaqus INP, FIL, and OBD Files
| Functionality | HyperView | |
| Animation Window | Plot Window | |
| Reads model file directly | INP, ODB | N/A |
| Reads results file directly | ODB (field) | ODB (field and history) |
| Reads translated results | FIL (hmabaqus) | FIL (hmabaqus)  FIL (hgopt_abaqus.exe)  |
| Supported field results (typically contoured) | FIL, ODB | ODB |
| Supported history results (typically plotted) | N/A | FIL, ODB |
| Abaqus version supported | 2023, 2022, 2021, 2020, 2019, 2018 | 2023, 2022, 2021, 2020, 2019, 2018 |
| Retains model's component names and IDs | INP, H3D from HM | N/A |
| Coordinate Systems | ||
| Can transform results to other system type inside application | Yes | N/A |
| Abaqus Results for ODB | ||
| POSITION = INTEGRATION POINTS | Yes | Yes |
| POSITION = CENTROIDAL | Yes | Yes |
| POSITION = NODES | Yes | Yes |
| POSITION = AVERAGED AT NODES | No | No |
| Abaqus Results for FIL | ||
| POSITION = NODES | No | No |
| POSITION = AVERAGED AT NODES | Yes | Yes |
| Abaqus Entities | ||
| Supports 1-D elements model | Yes | Yes |
| Supports 1-D elements results | Yes | Yes |
| Supports mass entities in model | No | Yes |
| Supports symmetric results on cylindrical surface and solid elements | Yes | N/A |
