fatigueprep
Translate files.
Translates Altair .h3d flexbody files into Ncode .fes/.asc files.
Translates Ncode .dac files into Altair .abf files.
Translates ADAMS .res files (modal participation factors) into Ncode .dac format.
Translates ADAMS .req files into Ncode .dac format.
fatigueprep <source> .h3d <target> .fes
fatigueprep <source> .h3d <target> .asc
fatigueprep <source> .dac <target> .abf
fatigueprep <source>.res <target>.dac
fatigueprep <source> .req <target> .dac [options]
Options
- <source>.req
 - Specifies the name of the ADAMS .req source file.
A .dac file will be created for each vector of data. Two numbers separated by an underscore will be appended to the <target> basename for each flexbody ID and mode ID.
