Tet Meshing
Use the Tet tool to fill an enclosed volume with first order or second order tetrahedral elements.
A region is considered enclosed if it is entirely bounded by a shell mesh (tria and/or quad elements). Hexahedral, wedge, and pyramid element configurations can also be generated during tetra meshing. These elements are typically generated when you need boundary layer type meshes on certain areas of the volume surface.
