| Rigids or RBE3's sharing dependent nodes |
Checks for rigid elements that share dependent nodes with other
rigid elements. |
Lists the failing elements. |
Deletes the failing rigid elements. |
Not supported. |
| Element has rigid loops |
Checks for rigid elements that form a closed loop; where the
dependent node of one rigid serves as independent node of the next
rigid in the loop. |
Not supported. |
| Free 1D nodes |
Nodes at the free end(s) of 1D elements. |
List the free nodes of 1D elements. |
NA |
Check the elements with free 1D and correct it. |
| Free 1D elements |
Checks for 1D elements that have one or more connection missing.
This check does not include RBE2 or RBE3 elements. |
Deletes the failing 1D elements. |
Not supported. |
| Duplicate 3D Elements |
Checks if any 3D elements share the same nodes in the same
order. |
Lists the duplicate 3D elements. |
Deletes the failing elements. |
Not supported. |
| Duplicate 2D Elements |
Checks if any 2D elements share the same nodes in the same
order. |
Lists the duplicate 2D elements. |
Not supported. |
| Duplicate 1D Elements |
Checks if any 1D elements share the same nodes in the same
order. |
Lists the duplicate 1D elements. |
Not supported. |
