MV-8002: Multi-Maneuver Events
In this tutorial, you will learn how to define end conditions for a maneuver or a sub-event, write parametric expressions, and to define events as multiple sub-events executed sequentially
- End conditions
- Conditions to end a particular maneuver before given simulation end time.
- Multi-maneuver events
- Events consisting for more than one maneuver – these maneuvers are executed sequentially.
- Parametric Expressions
- In a multi-maneuver event, expressions need to be re-evaluated before
the start of the maneuver in order to maintain the continuity of the signals.
- { Expression in Curly Braces }
- Instruction to driver to evaluate the expression before giving it to MotionSolve
- {SIGNAL}
- Evaluated as VARVAL(signal solver variable id)
- {SIGNAL_0}
- Evaluated as Signal Value at the end of last maneuver
- {%SIGNAL}
- Evaluated as {SIGNAL} – {SIGNAL_0}
Assemble the Vehicle
Page | Label | Selection |
1 | Model type | Full vehicle with advanced driver |
2 | Driveline configuration | Front wheel drive |
3 | Vehicle body | Body |
3 | Front subframe | None |
3 | Front suspension | Frnt macpherson susp (1 pc. LCA) |
3 | Steering linkages | Rackpin steering |
3 | Rear subframe | None |
3 | Rear suspension | Rear quadlink susp |
3 | Powertrain | Linear torque map powertrain |
3 | Tires | AutoTires |
4 | Steering column | Steering column 1 (not for Abaqus) |
4 | Steering boost | None |
5 | Front struts | Frnt strut (with inline jts) |
5 | Front stabilizer bars | Frnt stabar with links |
5 | Rear struts | Rear strut (with inline jts) |
5 | Rear stabilizer bars | Rear stabar with links |
6 | Front jounce bumpers | None |
6 | Front rebound bumpers | None |
6 | Rear jounce bumpers | None |
6 | Rear rebound bumpers | None |
7 | Disk brakes | Disk brakes |
7 | Front driveline | Independent fwd |
8 | Aerodynamic Forces | None |
9 | ABS/ESP System | None |
9 | Traction Control | None |
10 | Drive system | Altair Driver |
11 | Finish |
Adding Driver Analysis
Write the Altair Driver File (ADF)
We will model a Fish Hook Event using three sequential maneuvers.
