Design Optimization
In the aircraft industry, mass plays a critical role in deciding aircraft performance. The amount of lift required increases with the increase of mass, thereby increasing the drag and thrust on the aircraft. To overcome this, additional fuel would be needed, which would eventually increase the mass. Thus, it is important to account for structural mass in an aircraft and optimization is one such technique that can be used to obtain efficient results for aircraft structures.
Topology Optimization
Figure 1 shows the results from the topology optimization of a helicopter performed in OptiStruct. In this case, the objective is to minimize mass, with weighted compliance as the constraint.
Failsafe Topology Optimization
