pltIPlot Autoscale
Forces the plot to recompute the minimum and maximum values for its axes.
pltIPlot_handle Autoscale
Tcl Modify
pltIAxis SetAutoFit must be set to true for pltIPlot Autoscale to be enabled.
This method uses the current curve data to determine the minimum and maximum values. It may be necessary to call Recalculate first for recent data changes to be considered.
Returns success or an error code.
