pltIPlot CutHorizontalAxis
Cuts a horizontal axis.
pltIPlot_handle CutHorizontalAxis axis, append_future
Tcl Modify
This command cuts a horizontal axis based on the user-input axis index.
- axis
- The axis index (position in the axis list) that you want to cut.
- append_future
            - true
- Indicates the cut is added to a memory.
- false
- Indicates that the cut is not added to memory. This way, multiple cuts can be made and pasted at the same time, rather than copying and pasting each one individually.
Examples
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot CutHorizontalAxis 1 trueErrors
Keywords
Tcl
XY Plot
Modify
