pltIPlot CopyPhaseDatum
Copies a phase datum.
pltIPlot_handle CopyPhaseDatum datum, append_future
Tcl Modify
This command copies a phase datum based on the user-input datum index. A phase datum is a line that goes from the center outward in the polar plot. It is used for comparison.
- datum
- The datum index (position in the datum list) that you want to copy.
- append_future
            - true
- Indicates the copy will be added to a memory.
- false
- Indicates that the copy is not added to memory. This way, multiple copies can be made and pasted at the same time, rather than copying and pasting each one individually.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot CopyPhaseDatum 1 true;Errors
Keywords
Tcl
Polar Plot
Datum
Modify
