pltIPlot CutVerticalAxis
Cuts a vertical axis.
pltIPlot_handle CutVerticalAxis axis, append_future
Tcl Modify
This command cuts a vertical axis based on the user-input axis index.
- axis
            The axis index (position in the axis list) that you want to cut.
- append_future
            - true
- Indicates the cut is added to a memory.
- false
- Indicates that the cut is not added to memory. This way, multiple cuts can be made and pasted at the same time, rather than cutting and pasting each one individually.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot CutVerticalAxis 1 trueErrors
Keywords
Tcl
XY Plot
Modify
