pltIPlot SetUniformAspectRatio
Sets the plot to use a uniform aspect ratio.
pltIPlot_handle SetUniformAspectRatio true, false
Tcl Modify
- True
- The plot uses a uniform aspect ratio.
- False
- The plot does not use a uniform aspect ratio.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWindowName 1
myWindowName GetClientHandle myPlotName
myPlotName SetUniformAspectRatio trueErrors
Returns success or an error code.
