pltIPlot CopyNote
Copies a note.
hwIPlot_handle CopyNote note, append_future
Tcl Modify
This command copies a note based on the user-input datum index.Inputs
- note
- The note index (position in the note list) that you want to copy.
- append_future
            - true
- Indicates the copy is added to memory.
- false
- Indicates that the copy is not added to memory. This way, multiple copies can be made and pasted at the same time, rather than copying and pasting each one individually.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot CopyNote 1 false;Errors
Keywords
Tcl
XY Plot
Notes
Modify
