pltIPlot PasteHorizontalAxes
Pastes previously copied or cut horizontal axes.
pltIPlot_handle PasteHorizontalAxes index
Tcl Modify
This command pastes previously copied or cut axes into the axes list.
- index
- The index (position number) where you want to insert the axes. PasteHorizontalAxes pastes the user-input index and moves the list down one position if it is at or below that index
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot PasteHorizontalAxes 3;Errors
Keywords
Tcl
XY plot
Modify
