pltIPlot CopyCurve
Copies the curve to the internal clipboard.
pltIPlot_handle CopyCurve index, append
Tcl Modify
- index
- The number of the curve.
- append
            - True
- Appends the curve to other copied curves in the clipboard.
- False
- Replaces the contents of the clipboard with the curve.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName CopyCurve 1 0
myPlotName PasteCurve 0Errors
Returns success or an error code.
