pltIPlot CopyVerticalDatum
Copies a vertical datum.
pltIPlot_handle CopyVerticalDatum datum, append_future
Tcl Modify
This command copies a vertical datum based on the user-input datum index. A datum is a line used for comparisons.
- datum
- The input for the datum variable is the datum index (position in the datum list) that the you want to copy.
- append_future
            - true
- Indicates the copy is added to a memory.
- false
- Indicates that the copy is not added to memory. This way, multiple copies can be made and pasted at the same time, rather than copying and pasting each one individually.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot CopyVerticalDatum 1 true;Errors
Keywords
Tcl
XY Plot
Datum
Modify
