pltIPlot PasteNotes
Pastes previously copied or cut notes.
pltIPlot_handle PasteNotes index
Tcl Modify
This command pastes previously copied or cut notes into the notes list.
- index
- The index (position number) where you want to insert notes. PasteNotes pastes the user-input index and moves the list down one position if it is at or below that index (as to make room for the paste).
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot PasteNotes 3;Errors
Keywords
Tcl
Note
Modify
