PARAM, CHECKMAT
Bulk Data Entry Activates material property checking.
Parameter Values Description
CHECKMAT <YES, NO, FULL>
Defaults = See Comments
YES (Default)
The material properties for all referenced material definitions are checked for adherence to the default material requirements as described on the Material Property Check page. The amount of output is limited.
NO
Mathematical requirement checks only are performed for all referenced material definitions.
FULL
Material property checks are performed as when the value is YES, but all violations are output.
  1. When this parameter is not specified in the input file, the default is equivalent to PARAM,CHECKMAT,YES.
  2. When this parameter is present in the input file without any argument (PARAM,CHECKMAT), the default is equivalent to YES,
