Bulk Data Entry Controls the transverse shear stress calculation for composite shells,
(PCOMP, PCOMPP, PCOMPG) and
continuum shells (PCOMPLS).
| Parameter |
Values |
Description |
| COMPSHST |
<0, 1,
2> |
- = 0 (Default)
- Transverse shear stress is determined from shear
forces with respect to the two neutral axes,
respectively. Only laminate direct bending stiffness
is considered. Extension-bending coupling is
excluded.
- = 1
forces assuming two separate cylindrical bending
modes. Laminate level extension-bending and bending
compliance matrices are considered in a way that
does not produce
, and
does not produce
- = 2
can
also produce
, and
can
also produce
- COMPSHST is applicable to continuum shells
(PCOMPLS) when there is only one element in the
composite stack direction. It should not be used when there are multiple
elements in the composite stack direction.
