PARAM, K4CUTOFF
Bulk Data Entry Sets cut-off value if the low rank representation for the structural damping matrix is selected.
| Parameter | Values | Description |
| K4CUTOFF | <Real> Default = 0.1 |
PARAM,
K4CUTOFF relates to the FastFRS
interface. If the low rank representation for the structural damping matrix is selected, a cut-off value must be set. The value is set using K4CUTOFF. Refer to FastFRS (Fast Frequency Response Solver) in the User Guide for more details. |
