PARAM, POSTEXT
Bulk Data Entry Outputs the modal complex stiffness matrix and modal viscous damping matrix to the OUTPUT2 results file.
| Parameter | Values | Description |
| POSTEXT | <YES,
NO> Default = NO |
If YES,
the modal complex stiffness matrix (KHH) and, if it exists, the
modal viscous damping matrix (BHH) are written to the
.op2 file when frequency response analysis
is performed. The modal complex stiffness matrix is: Where, G is the PARAM, G structural damping value and [Kge] is the structural damping matrix based on the structural damping values on the MATi data. The modal viscous damping matrix is: |
