PARAM, OGEOM
Bulk Data Entry Outputs model data to the OUTPUT2 results file.
| Parameter | Values | Description |
| OGEOM | <YES, NO> | Controls the output of
model (geometry) data to the .op2 file. This
functionality is also controlled by the
MODEL/NOMODEL option on the
OUTPUT, OP2
I/O option, but this parameter setting will
override the OUTPUT, OP2 setting.
