Specify Heat Exchangers
Identify the inflow, outflow, inertial resistance, and viscous resistance of heat exchangers, which are modeled as a porous medium.
Identify heat exchangers in the following ways:
Use the Identify Heat Exchanger tool.
- Right-click on a part in the modeling window or the Model Browser and select from the context menu.
- Select a part in the modeling window or the Model Browser then change the Identify As field to Heat Exchanger Inlet/Outlet/Wall in the Property Editor.
- Open the Property Editor and review the parameters associated with a particular heat exchanger by left-clicking on parts identified as a heat exchanger in the Model Browser.
- Define additional heat exchangers by clicking
in
the Heat Exchangers dialog. This will increase an
internal index to number all heat exchangers. - Use the right-click context menu in the Heat Exchangers dialog to delete and rename heat exchangers.
