hwIPage CopyWindow
Copies a window.
hwIPage_handle CopyWindow window_index
Tcl Modify
This command copies a window in the page based on the user-provided window index.
- window_index
- The index of the window that you want to copy.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 CopyWindow 2;
Error
Keywords
Tcl
Modify
