hwIPage GetMasterSyncBlockID
Gets the sync block ID of the master, if it is set.
hwIPage_handle GetMasterSyncBlockID
Tcl Query
The ID of the master sync block. This is only relevant if the sync table generation policy is MASTER_BLOCK.
None.
