hwIPage PasteWindow
Pastes a previously copied window.
hwIPage_handle PasteWindow window_index
Tcl Modify
This command pastes a previously copied window onto an existing window.
window_index
The position of the window that you want to paste the copied window onto.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 PasteWindow 3;
Error
Keywords
Tcl
Modify
