hwIPage SetAnimationFrameRateTracking
Enables the animation frame rate tracker.
hwIPage_handle SetAnimationFrameRatesTracking enable
Tcl Modify
This command determines whether the animation frame rate tracker is enabled.
enable
True
If you want the animation frame rate tracker to be on.
false
If you do not want the frame rate tracker on.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 SetAnimationFrameRatesTracking true;
Error
Keywords
Tcl
Animation
Modify
