hwIPage SetMasterSyncBlockID
Sets the new master sync block ID and recalculates the master sync table. This command is ignored if the sync table generation policy is not set to MASTER_BLOCK first.
hwIPage_handle SetMasterSyncBlockID masterID
Tcl Modify
masterID
A valid sync block ID that will be the new master sync block.
Error
Success (0) or an error code.
