*aletanktests()
Starts an aletanktests block.
*aletanktests (config)
HyperMesh Template Command
This command must be accompanied by a *output() command at the end of the block.
- config
- An integer that defines the config of entities in the block. If not specified, all entities are considered for the block.
To write out all aletanktests with the format:
*aletanktests(id,"name")
*aletanktests()
*format()
*string("*aletanktests(")
*field(integer,id,0)
*string(",")
*field(quotedstring,name,0)
*string(")")
*end()
*output()
Version History
2019
