*cards()
Starts a Control Card output block.
*cards (card name)
HyperMesh Template Command
- card name
- The name of the card to output.
To output the CTRL_TITLE card the following commands may be used:
*cards("CTRL_TITLE")
*format()
*string("TITLE / ")
*string(" ")
*fieldleft(string,$TITLE_VAL,48)
*end()
*output()
Requires a *output() at the end of the block.
