*resultsimulations()
Starts a resultsimulations block.
*resultsimulations (config)
HyperMesh Template Command
Requires an *output() command at the end of the output block definition.
- config
- An integer that defines the config of entities in the block. If not specified, all entities are considered for the block.
To write out all resultsimulations with the format:
*resultsimulations(id,"name")
*format()
*string("*resultsimulations(")
*field(integer,id,0)
*string(",")
*field(quotedstring,name,0)
*string(")")
*end()
*output()
Incorrect usage results in an import error.
Version History
2021.2
