Changes how real numbers are written to the output deck.
*compressreal
(flag)
HyperMesh Template Command
This command changes how real numbers are written to the output deck. The default value is
1. If used along with *realprecision, trailing zeros will be converted to
blanks after the digits specified by *realprecision. For example,
*realprecision(4) forces four digits to be written, even if they are
zeros.
- flag
- Trailing zeros are written as blanks.
- Zero is not written to the left of the decimal.
- In addition to performing compression, this command will add extra significant digits
where applicable, while also rounding off precisely at the last digit. The compression
is performed in accordance with the following rules and conditions:
- This flag is applicable only for output of real numbers using any of the *field
commands that have "real" as their first argument, and also have a non-zero width
argument. Thus, the command will have no effect on the output produced using
*field(exponential,value,8), or *field(real,value,0), for instance.
- For values that are either too large or too small such that use of the ‘E’ is
necessary to represent the number within the given width, the following conditions are
applied:
- By default, ‘E’ is omitted, and an extra significant digit is added, if applicable.
However, ‘E’ can be output, by passing a custom export string to the command
*feouputwithdata. Please refer to the documentation of that command
for more details.
- Any leading zeros on the exponential part are always omitted. Instead, additional
significant digit(s) are output, where applicable.
- For values that do not require the use of ‘E’, the following conditions apply:
- For a number whose absolute value is less than 1.0, the zero to the left of the
decimal point is omitted if doing so results in adding an extra significant digit.
- For a whole number whose absolute value is greater than or equal to 1.0, the zero to
the right of the decimal point is omitted if doing so results in a more accurate
representation of the number within the given width.
- Trailing zeros that do not contribute to the accuracy of a number are always replaced
with blanks, leaving only one zero, at the most.
- This flag also provides a means of rounding off real numbers whose absolute value is
within a specified tolerance, to zero. This option is off by default, but can be turned
on by passing a custom export string to the command
*feoutputwithdata. Please refer to the documentation of that command
for more details.
Using *compressreal(1) causes HyperMesh to
write numbers such as 0.0000 as 0.0.
Using *compressreal(2) causes HyperMesh to
write numbers such as 0.123456 as .123456.
The table below has examples of output obtained using *compressreal(3).
The examples assume default options, that is, without the use of the custom strings
mentioned above in *feoutputwithdata.
